Overview to Cycle Modelling in CUBE
This procedure will replicate the bicycle route choice of a user. It performs a HIGHWAY assignment twice; once for skimming and once for assignment. In addition, it would be suitable to select the proper variables in the generalized cost functions as well as calibrate the coefficients in the utility functions.
Step 1: Run Highway for only one iteration to get skimming values
Step 2: Run Choice in Matrix to compute the probability for each route using discrete choice model
Step 3: Apply probabilities to split the original O-D trips to each route
Step 4: Run Highway for only one iteration to assign the bicycle trips for each bicycle route
