Key Definitions:
Here are some definitions and concepts that will be helpful when trying to understand Highway Assignment:
Zone: Portion of the study area with homogenous land use, socio-economic and demographic characteristics
Zone Centroid: Assumed point in a zone that represents the origin or destination of all trips to or from that zone
Centroid Connector: Imaginary link representing the local streets within a zone. Linking the zone to the network loading point.
Network: Contains the transport network of the study area. Represented by links and nodes.
OD Demand Matrix: Demand for travel between all zones in a study area. (N x N)
Skim Matrix: Indicator matrix containing zone to zone statistics.
Generalized cost: Generalized costs (GC) are the costs perceived by the traveler as they decide which mode to use. These sum time and monetary costs and use the Value of Time to convert to a single unit.
Highway Assignment Overview:
Highway assignment deals with finding the least generalized cost path between each origin and destination in a network.
It is an iterated procedure looking for convergence or equilibrium, which means that every user in the system reaches the path with the best general cost, there is no possible further reduction. For example, in the case that travel time is the only factor being accounted, equilibrium is reached when all users achieve the best travel time available for their trips.
Inputs for a Highway program include (among others):
Can be built from (by conversion tools):
-Shape Files
-Dbf files
-ASCII files
Cube format network formats (no conversion):
- Geodatabase Networks (.mdb/ .gdb)
- Binary .NET Networks (no associated geometry to links (straight lines only)). True shape of the links can be activated with an underlying shapefile
- Matrices for Highway Assignment must be SQUARE matrices. Where rows represent the Origins and columns represent Destinations.
- In CUBE you can have several tables/ matrices inside one Matrix file which are accommodated in tabs at the top.
- A single CUBE Format Matrix file (.mat) can hold up to 255 matrices/ tables.
- Matrices can come originally in a csv, dbf or fixed format and with the help of CUBE tools can be converted into a CUBE Format Matrix file.
Outputs for a Highway program include (among others):
Highway Assignment Process in Voyager:
The Highway program in CUBE has as its primary function to Build Paths between all origin destination pairs. After paths are built it is possible to skim network variables and assign trips to the network.
The method used to assign the OD matrix to the network uses an iterative approach:
Steps 3 to 5 are repeated until some criteria for termination is reached.
The highway program applies the above-mentioned method by dividing the process in 5 phases, which are all coded/scripted with control statements:
In the Highway Program Script we would write the following control statements:
SETUP Phase, which is an implicit phase (it does not have a header)
We will set in this case: COMBINE=EQUI as well as set the iteration information (Maximum number of iterations) MAXITERS and/or set convergence criteria. (The program will finish running once it meets either the convergence criteria or maximum number of iterations, whichever comes first).
LINKREAD Phase:
Defines required values for each link like:
C=LI.CAPACITY
t0=(LI.DISTANCE/LI.SPEED)*60
DISTANCE=LI.DISTANCE
ILOOP Phase:
In this phase we will be creating paths from each origin zone to every destination using command PATHLOAD.
Other keywords used are:
Lets take a simple example on how Highway Assignment works.
The schematic diagram shows that we have:
We have to assign a capacity and travel time to each link in the figure t0 and c which is primarily done in LINKREAD phase.
In ILOOP Phase, we build shortest paths from every zonal pair or for every origin/destination. In our example, we start building all possible paths from 1 to 2 (Origin-Destination) and calculate the overall travel time. In this process, we find 3 paths as below:
Path 1 (1—100, 100-2):
t0= 6 mins
Path 2: (1-100,100-101,101-2)
t0= 12 mins
Path 3: (1-101,101-2)
t0= 8 mins
After building all the possible paths we find the best path as Path 1 (1-100, 100-2) as it is the one with least travel time. On this path, we do All or Nothing (AON) assignment for Iteration 1 (t0).
Once a AON path is found, we load the demand for that OD pair to this path. Once done, we move to ADJUST phase.
ADJUST Phase:
In Adjust phase, we define functions that will be used in the Highway Program to update the travel times on each link or update the generalized cost for each link and this will be largely dependent on congestion of the respective link.. In Adjust phase, we combine all the volumes from every OD pair on a single subject link including adding other vehicles from other user-classes. The combine is done by V as below.
V=VOL[x1]+VOL[x2]
Where V computes the total volume on a link after an iteration.
TC[n]=T0*(1+α(V/C)β
Where TC stands for congested time
In our example, after ADJUST phase, the travel times are now updated as below.
Once the updated Travel Times are available, we move to ILOOP Phase again where Paths are built again and a new AON Best Path is chosen. In our example, the new AON path is Path 3: 1-101, 101-2. Then, the COMBINE=EQUI statement will decide how many trips will go in each path, given the new best path. Trips after both iterations are split between Iter 1 Best Path and Iter 2 Best Path using the equilibrium calculations or based on ‘lambda’ values.
After two iterations it is noticeable that the assignment will produce variation in the selection of a Best Path which is why the CONVERGE Phase is needed.
CONVERGE phase
Suggestions for HW Assignment convergence:
For more details on CUBE’s Highway Assignment, please refer to CUBE Voyager > Highway documentation.
For examples on How to do Highway Assignment in CUBE Voyager refer to other Wiki Posts.
