CUBE consolidation - what's changed?
With the transition from Citilabs to Bentley Systems, the release of our CUBE CONNECT Edition (CE) version and future CE versions to come, we have made some subtle changes to the way we provide CUBE modules. We believe this latest change gives the most functionality in the simplest way and is summarized below:
It is also important to note that the cost of the new 'CUBE', be it a new purchase or renewal, is the same as the former CUBE Base + CUBE Voyager price.
ALL modules in the above table are included in ONE installation package 'CUBE'. The license you own will permit you to use CUBE and any additional 'add-on' modules that you have purchased.
For example:
Question: "Previously, our invoice said we had 1x CUBE Base and 1x CUBE Voyager, now we only have 1x CUBE. Are we getting fewer products and functionality? And what about price?"
Answer: You are getting the same functionality or more for the same price. Since we have now bundled CUBE Base and CUBE Voyager together, you will only have one item on your renewal and that's simply 'CUBE'. This new bundle actually allows you to use all core strategic modelling tools (CUBE Base, Voyager, Analyst and Cluster) at the same price. The software interface will still reference individual product names as they themselves have not changed.
For more information on each of the modules and the programs contained within, please see the Wiki section on Cube: https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0101987
