| Product(s): | OpenPlant Support Engineering |
| Version(s): | V8i |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Bentley Product Advantage Group |
What are the prerequisites required to install OpenPlant Support Engineering?
The Desktop Prerequisite Pack v08.11.09.03 needs to be installed to your workstation prior to the installation of OpenPlant Support Engineering V8i incase internet connection is not available at time of install. The Desktop Prerequisite Pack is available from the Web Software Downloads/MySELECT CD area of SELECTservices Online.
Does it Require ProjectWise to Install?
ProjectWise is Optional. ProjectWise is only required when connecting to OpenPlant Model Server.
Version to Check:
- ProjectWise Server 8.11.9 with ProjectWise Explorer client 8.11.9.590, 8.11.9.574, 8.11.9.559
What Operating Systems does it Support?
- Microsoft® Windows 7 (64 Bit)
- Microsoft® Windows 8.1
- Microsoft® Windows 10 (64 Bit)
What are OpenPlant Support Engineering Workflows?
- OpenPlant Support Engineering can be used with referenced i-models from OpenPlant Modeler and structural tools such as ProStructures.
- OpenPlant Support Engineering can also works in conjunction with OpenPlant Model Server in a component based workflow by referencing out piping components or work breakdown structure elements in order to begin work and then checking in support components upon completion to OpenPlant Model Server. These support objects can then appear in isometrics generated from OpenPlant Isometrics Manager.
What are the Tools or Features provided by OpenPlant Support Engineering?
Accurate placement of supports, support assemblies, and support placeholders (locators)
Manual and automated placement algorithms
Universal placement dashboard
Supports and support parts from multiple vendor catalogs
Assembly creation tools
Automatic support drawing generation
Additional tools for annotation and notes.Bill of materials automatically generated.
- Bill of materials automatically generated.
Drawing border can be customized with multiple views, bill of materials, notes and part callout sections.
- Flexible report generation.
- Supports for Piping, HVAC and Raceway.
A detailed explanations for all above can be found in OpenPlant Support Engineering articles.
What are the current limitations under OpenPlant Support Engineering?
- Structural objects from Prosteel are not currently intelligently recognized by the program. For More details refer help file.
- Using .dgn files for interaction between the two products is currently not supported.
Is it Possible to Import Regional standard catalog for Steel Section?
- Structural steel section catalog can be imported in OpenPlant Support Engineering using Project Dashboard. For more information check Help File.
- User may use SQLlite application to create a DB file which will further get imported inside the Project Dashboard.
Is it Possible to Import the data available in excel file format for Steel Section?
- Yes with new SS6 release of OpenPlant Support Engineering, it is possible to import the data in excel format with an option "Catalog Loader" present in Project Dashboard.
Is it Possible to use AutoPLANT drawings?
- Yes! It support AutoPLANT.dwg. This is support from SS6 Version.
Can I get list of what's new items for SS6 release?
- Yes! you can check either in Readme file or click here>>>
External Links
Check Videos Content - LEARN Server
Comments or Corrections?
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
