| Version(s): | 08.11.11.XXX |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Component and Graphics |
| Original Author: | Kunal Kiran, Bentley Product Advantage Group |
To Change the graphics of Pipe union from Hexagonal to Circular
Currently in OpenPlant Modeler, Pipe Union has a Hexagonal Graphics.
As per project requirement it might be needed to have a Pipe Union component with Circular Shape.
This can be achieved in two ways:
- Editing the Schemas to make all the Pipe Unions appear with Circular Graphics
- Editing the Specs to make selected Pipe Unions appear with Circular Graphics
Case 1: Editing the Schemas to make all the Pipe Unions appear with Circular Graphics
- Launch Class Editor from OpenPlant Project Administrator
- Open OpenPlant_3D schema and supplement it with
-> OpenPlant_3D_Supplemental_Information_3DComponent.01.07.ecschema.xml
-> OpenPlant_3D_Supplemental_ModelingViews.01.07.ecschema.xml
-> OpenPlant_3D_Supplemental_Modeling.01.07.ecschema.xml
- Browse to classes -> Plant Base Object -> Named Item -> Device -> Piping component -> Inline Pipe Component -> Pipe union
- Go to Properties tab and search for FLATS property and select it
- Click on Custom Attributes -> Add/Remove..
- Remove the attribute OpenPlant_Physical_Catalogue_Property_Map by double clicking it
- Click Ok and save the schemas and exit Class Editor
- Launch OpenPlant Modeler and verify results
CASE 2: Editing the Specs to make selected Pipe Unions appear with Circular Graphics
- Browse to your Spec location and Open your Spec in MS_ACCESS; Say mEX-OPm located at C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Specs Databases
- Go to MISC_FIT table;Freeze EC_CLASS_NAME and FLATS columns
- Filter the EC_CLASS_NAME to display only PIPE_UNION
- Edit the values of FLATS to 0 for the records for which you want circular graphics
- Save the Spec and Exit.
communities.bentley.com/.../12009.component-openplant-modeler
Comments or Corrections?
