| Product(s): | OpenPlant Support Engineering |
| Version(s): | 08.11.11.235 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Project Dashboard |
| Subarea: | Support Drawing |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To display support Key Plan with respect to nearest key plan in Support Drawing.
In OpenPlant Support Engineering, user requirement is to generate support key plan for grids. With latest release of OpenPlant Support Engineering, support key plan with respect to nearest column appear in support BOM if any grids are present in Model. Below steps highlights key feature of it.
Also refer Help file for new features and information regarding OpenPlant Support Engineering.
communities.bentley.com/.../project-dashboard-openplant-support-engineering
