| Version(s): | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | OpenPlant Specification Generator |
| Subarea: | - |
| Original Author: | Bentley Product Advantage Group |
OpenPlant end conditions are 2 to 3 letter abbreviations of many manufacture end types. While many abbreviations are obvious others such as BWT ( TriClove Butt Weld), and PCM (Plastic Threaded Male) are not. Use this table to compare the spec's end condition to its intended end type.
| OpenPlant Joint type | OpenPlant End Condition | Long Description |
| BEVELED_END | BV | Beveled |
BUTT_WELD |
BW BWT |
Butt Weld TriClove Butt Weld |
| CLAMP_FEMALE_END | TCF | Triclover Clamp Female |
| ICF | HiPurity I Clamp Female End | |
| CLAMP_MALE_END | QCM | HiPurity Quick Clamp Male End |
| ICM | HiPurity I Clamp Male End | |
| COMPRESSION_END | AWF | Victalic AWWA Female Plain |
| CE | Plastic Clamped End | |
| FEMALE_CAM_AND_GROOVE_END | IGF | Victaulic Female Grooved IPS |
| AGF | Victaulic Female Grooved AWWA | |
| CGF | Victaulic Female Grooved Copper | |
| FEMALE_COUPLING_END | FCE | Female Coupling End |
| FEMALE_HOSE_END | FHE | Flex Hose Female end |
| FERRULE | TCM | Triclover Clamp Male |
| FLANGE_GROOVE_FEMALE_END | FGF | Victaulic IPS Flange Female Grooved End |
| FLANGED | FL | Flanged |
| FLA | Victauilc Flange Adapter End | |
| FLARE_END | FA | Flared End |
| HUB_END | FLT | Base Hub End |
| LAP_JOINT_END | LAP | Lap Joint |
| LUG_END | LUG | Lug Flanged |
| MALE_CAM_AND_GROOVE_END | AGM | Victaulic Male Grooved AWWA |
| IGM | Victaulic Male Grooved IPS | |
| CGM | Victaulic Male Grooved Copper | |
| FGM | Victalic AWWA Male Grooved End (Flex) | |
| MALE_INSERT_END | MIE | Flex Hose Male Insert End |
| MECHANICAL_FEMALE_END | MJF | Ductile Female Mechanical Joint |
| LR | Ductile Mechanical Lock-Ring Joint Female End | |
| PFS | Push-Fit Socket End | |
| FR | Ductile Mechanical Joint Flex Ring Female End | |
| FRF | Ductile Flare | |
| FS | Ductile Mechanical Joint Fastite Female End | |
| MECHANICAL_MALE_END | LHM | Locked Hydrant male |
| MJM | Ductile Mechanical Joint Male End | |
| MTM | Ductile Mechanical Tybar Joint Male End | |
| PLAIN_END | PL | Plain |
| NST | National Standard Thread | |
| INP | N/A | |
| INS | Plastic Insert End | |
| PUSH_ON_END | PFS | Push-Fit Socket End |
| PUSH_ON_RESTRAINED_END | FR | Ductile Mechanical Joint Flex Ring Female End |
| SLIP_ON | SOF | Slip On |
| SOCKET_WELD_FEMALE | SWF | Socket Weld Female |
| PWF | Plastic Socket-Weld Female End | |
| SPF | N/A | |
| CUP | Copper Socket Weld Female | |
| BWF | Butt Weld Female | |
| SOCKET_WELD_MALE | SWM | Socket Weld Male |
| SEM | Ductile Spigot Male End | |
| *** | Victaulic Copper Socket-Weld Male End | |
| THREADED_FEMALE | SCF | Screwed Female |
| PCF | Plastic Threaded Female End | |
| TBF | Triclover Threaded Bevel Female | |
| THREADED_MALE | SCM | Screwed Male |
| PCM | Plastic Threaded male End | |
| TBM | Triclover Threaded Bevel Male | |
| TRAY_CONNECTOR | TC | Cable Tray |
| CC | Cable Channel | |
| CTB | Compact Termination Box | |
| VICTAULIC_PLAIN_END | VPL | Wafer Flanged |
| WAFER | WAF | Wafer End |
See Help Menu for additional information.
