| Applies To | ||
| Product(s): | Isogen | AutoPLANT AutoIsogen | |
| Version(s): | 08.11.xx.xxx | |
| Environment: | Windows 7 (64 bit) | |
| Area: | Settings/Attributes | |
| Subarea: | ||
| Original Author: | Abhijit Bute, Bentley Product Advantage Group | |
Weld summary is required in isometric to calculate the weld quantity in project. Following steps will help to get detailed weld report in isometric
Style 3 weld type of Weld Summary
This type of weld summary box may only be used in conjunction with a User defined backing sheet. The heading and enclosure line is part of of the backing sheet and the data items are edited in using X-Y coordinate data that is specified in wdf.
Refer following wdf file.
Option 53 setting should be (No weld summary box)
