| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | Tree Manager |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To fix the message Too many results(1010).Select this to see items in details.
With the use of multiple pipelines, the maximum limit to display the levels in item tree browser is set to 1000. Anything exceeding this value would give a message like displayed below.
See below steps to fix & allow user to view all components in item browser.
If there is still some problem, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../how-to-disable-server-tree-hierarchy-in-active-tree-of-item-browser
