| Version(s): | 08.11.09.XXX |
| Environment: | Windows 7 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
In OpenPlant Modeler, users requirement is to see Nozzle Facing Property in Element Information dialog.
communities.bentley.com/.../how-to-populate-number-property-on-pipe-segment
communities.bentley.com/.../how-to-move-properties-between-categories
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
