| Applies To | ||
| Product(s): | OpenPlant Modeler | |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) | |
| Environment: | Windows 7/8.1/10 (64 bit) | |
| Area: | Reference | |
| Subarea: | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
When Pro-Steel or ProStructure models are attached as reference in OpenPlant Models, sometimes users experience crashes or structural graphics do not appear correctly which is very annoying for the user.
Install the latest version of Pro-Structures Plug-in for Bentley Products as highlighted in below picture or if you find any newer version then you can install the same.
Click Here to access Bentley's Software Fulfillment Center.
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../errors-logs-messages-crashes---openplant-modeler
