| Version(s): | 08.11.09.564 (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | - |
| Subarea: | - |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Troubleshoot spec opening issues for unavailable catalogs in OpenPlant Specification Generator.
In OpenPlant Specification generator, few specs were unable to open and throws an error ‘Unable to find Catalog’. For instance, while opening a default catalog mcablet for a metric project, in OpenPlant Specification generator, it prompts an error. ‘Unable to find catalog:%NETWORK_ROOT%\Catalogs\METRIC\Cablet.mdb, Do you want to browse for catalog?”
However to avoid similar situation, user can create a temporary catalog containing same field to allow the spec to open.
See Help Menu for additional information.
communities.bentley.com/.../openplant-specification-generator
