| Version(s): | 08.11.09.XXX(SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | OpenPlant Specification Generator |
| Subarea: | - |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To create missing class data by converting it through specification generator.
With the use of Specification generator, under catalog editor, component table does not includes few classes which are present inside the default schema. User wanted to get it added inside the Catalog Editor. Below steps describes the process of adding it in table. This is the case for Mixed Metric Environment. User need to follow below steps on realizing the catalog information in specgen.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../openplant-specification-generator
