| Version(s): | 08.11.09.XXX (SS5) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
This article will explain how can we pull the information from properties on the pipeline class using GetRelatedInstance expression to show up on SUPPORT class. In this article, NOMINAL_DESIGN_TEMPERATURE property on PIPING_NETWORK_SYSTEM class is taken as an example.
communities.bentley.com/.../component---openplant-modeler
