| Version(s): | 08.11.09.XXX (SS5) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Currently, when using Auto-Match option mating components get the property from adjacent components but they are not actually queried from spec. User requirement was to query the mating components based on rating of component placed. However, same procedure can be followed in case of other properties.
NOTE: Currently, this will not work correctly with inline placement of components. However, with manual placement of components this setting works perfectly.
communities.bentley.com/.../component---openplant-modeler
