| Product(s): | AutoPLANT Piping | |
| Version(s): | 08.11.09.140 | |
| Environment: | Windows 7 64 bit | |
| Area: | General | |
| Subarea: | | |
| Original Author: | Artiom Jakubovic, Product Advantage Group | |
Problem Description
This message appears upon AutoPLANT load and followed by next messages.
COM Component Creation Error
Error creating instance of COM component APHLR
COM Error Unknown ERROR code 0x80048154
Error creating instance of COM component:
APHLROpt1onsAN18.HLRРrawModeOptions
COM Error: Unknown ERROR code 0x80040154
Exception in AT_SYS_GETVERSIONBINNAME ARX Command
Unhandled Exception E06D7363 (e06d7363h) at address FCC19E5Dh
Steps to Resolve
- In several occasions this issue was resolved by updating Graphic Card Drivers to latest available. Restart is required after update.
- In some cases when NVIDIA graphic card with NVIDIA Optimus Technology is used in order to resolve this issue NVIDIA Optimus should be disabled in BIOS (Please refer to you computer user manual) . After disabling it in BIOS, NVIDIA drivers must be reinstalled and machine should be restarted.
- Download communities.bentley.com/.../NGUtils-09.190.zip
- Unzip the folder NGUtils 09.190.zip to the path: C:\Program Files (x86)\Bentley\Plant V8i\Bin\NGUtils\
- Reregister TypeLibUtils.dll using string below:
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase "C:\Program Files (x86)\Bentley\Plant V8i\Bin\NGUtils\x64\TypeLibUtils.dll
Comments or Corrections?
