| Version(s): | 08.11.09.XXX (SS5) |
| Environment: | Windows 7 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
When there are multiple records of TopWorks (say HAND_WHEEL) in the spec then while placement of valves (Gate Valve & Globe Valve) software does not differentiate between the records and places the HAND_WHEEL with same dimension on both the valves.
communities.bentley.com/.../12009.component-openplant-modeler
