How to Create new Drawing Attribute Combining Multiple other Drawing Attributes and Map it -v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX (SS5) | 08.11.11.XX (SS6)
Environment: Windows 7/8.1/10 (64-bit)
Area: Settings/Attributes
Subarea: Modifying Text and Annotation Settings
Original Author:Kestutis Mitkus, Bentley Product Advantage Group
To create new drawing attribute combining multiple other drawing attributes and map it with new text node in generated Isometrics of OpenPlant Isometrics Manager.
In OpenPlant Isometrics Manager, user requirement is to create new Text Node, which could be mapped with multiple drawing attributes. For example, user wants to create LINE_ID_TAG text node, which could show NOMINAL_DIAMETER, SERVICE, LINENUMBER and SPECIFICATION.
  1. Open node2da.txt and textnodes.txt files from your Isometrics style's config folder.
    For OpenPlant Modeler:
    C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\[...]\DataSet\Isometrics\Styles\[...]\Config
    For AutoPLANT Modeler:
    C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\[...]\Config\OpenPlant\Isometrics\styles\[...]\config
  2. We need to define LINE_ID_TAG variable with multiple attributes in textnodes.txt file and for this purpose we will use existing drawing attributes which are already mapped in node2da.txt file.
  3. At the beginning of textnode.txt file are information how drawing attribute definition can be created. With the help of this information I have combined existing attributes in to one.
    <DA name> = <expression>
    LINE_ID_TAG = LINE_ID: $(SIZE1)-$(SERVICE)-$(LINENUMBER)-$(SPECMAIN)
  4. Now map this new drawing attribute with new textnode in node2da.txt file
    70, LINE_ID_TAG
  5. Open same projects styles isoseed.dgn file and place this new text node in required position
  6. Save all changes, close isoseed, generate Isometrics and verify the results.
communities.bentley.com/.../how-to-reclaim-desired-text-node
communities.bentley.com/.../modifying-text-and-annotation-settings
Comments or Correction?
