| Product(s): | OpenPlant Modeler V8i |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | - |
| Subarea: | - |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
By default each new user is created using default settings and each user can edit those settings by his own requirements, but sometimes there is requirement, that major part of all required settings should be already prepared for all users. Below instruction will help to prepare existing environment to use Standards directory and prepare user preferences with all requirements for all users.
_USTN_SITE variable in msconfig.cfg file is set to look in .../Workspace/Standards directory. This default configuration was specially prepared for similar requirements to have special configuration files which could be used as standards.
Note: Required interface, preferences and other changes should be done only after all configuration steps are done, because on first time opening it is overwriting preferences with standard settings. After saving them it will always load last saved settings.
Now each time, by opening application with any user, any interface or any project, preferences will be same. As well each user will be able to edit those preferences and then all other users will see those changes.
communities.bentley.com/.../how-to-point-to-shared-workspace-of-openplant-modeler
