| Applies To | ||
| Product(s): | OpenPlant Modeler V8i (SELECT series 5) | |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) | |
| Environment: | Windows 7/8.1/10 (64 bit) | |
| Area: | Error/Logs/Messages | |
| Subarea: | Local-Roaming-Component Specs-Others | |
| Original Author: | Michelle Saucier, Bentley Product Advantage Group |
Problem Description
In OpenPlant Modeler, when placing pipe if the error " No Component found with initial selection from Specs" user can try and delete data source files to clear up the issue. However there might be several occasion where below solution work and resolve issues.
case-I
Steps to Resolve
case-II
while working at user's environment, pipeline manager dialog crashes when user tries to edit pipeline and thrown below message shown here.
Also it not allowing the system to get it close.
Steps to Resolve
communities.bentley.com/.../errors-logs-messages-crashes---openplant-modeler
Comments or Corrections?
Bentley's Product Advantage Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
