| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Specification Generator |
| Subarea: | - |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In OpenPlant Modeler, use of UBR/RBR types of branch is used through Branch table present in Specification Generator.
With the use of Specification generator, there is an option to define the branch types, such as UBR-RBR with Set-on/Stub-in types.
Following options are available:
- Use Branch table: With this option enabled, whenever there is a branching connection in Modeler, the component defined in Branch table will be inserted automatically.
- Show spec Selection Grid: This option will only be considered by Modeler if multiple components are selected in branch table. Then a Spec Record Selection is displayed allowing you to select a component from the list.
With the use of Branch table, modeler should get below option to select the branch types:
a. UBR_SET_ON – Un-reinforced Branch – Set ON
b. UBR_STUB-IN – Un-reinforced Branch – STUB-IN
c. RBR_SET_ON – Reinforced Branch – Set ON
d. RBR_STUB-IN – Reinforced Branch – STUB-IN
- Launch Open Plant Specification Generator & select project unit.
- Choose to load a spec through File menu option.
- After loading the spec, it will enable the Branch table editor to proceed for the modification in branch table.
- Select ‘Branch table Editor’ Option from ‘Tools’ menu.
- From drop down menu option, modeler should get default branch codes in drop down box. To select multiple branch code for the branch size, choose ‘…’ option to select from the list.
Note: For new branch codes, modeler could check ‘Branch Code editor’ option to add more entries in drop down list.
- Save & close the table and spec.
- Launch OpenPlant Modeler.
- After filling up the table with proper Branch code, modeler could be able to place it in OPM by enabling ‘ Auto Branch Table’ option.
- Also enable ‘Show Spec Grid for Auto Tables’ option to show all the list of entries done in branch table.
- While placement it will prompt Modeler to select these options.
See Help Menu for 'Branch Table’ & ‘Branch Code Editor’ for more details.
Comments or Corrections?
