| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Processing |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager, to open an intermediate file to review.
In OpenPlant Isometrics Manager, each isometrics drawing produces an intermediate file along with other supported file. This Intermediate file with an L00 extension can be found under working isometric folder. User might use this file for reviewing and debugging purpose, which does not require any workspace or specific environment to open this file. Below steps will aid user to get it open in OpenPlant Isometrics Manager environment. Below described case is based on OpenPlant Modeler and OpenPlant Isometrics Manager.
Note: Please mention the spaces and file path carefully.
If there is still some problem in using the key-in and opening an intermediate file, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
Also check OpenPlant Isometrics Manager "HELP" menu for details.
