| Product(s): | AutoPLANT |
| Version(s): | SS4, SS5, SS6, SS7, SS8 |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Dialog |
| Subarea: | Errors, Logs, Messages and Crashes |
| Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
Problem Description
FATAL ERROR: Unhandled e0434352h Exception at fd38a06dh while loading Component Preferences
Possible Reason
This error usually occurs because of bad profiles.
Steps to resolve
communities.bentley.com/.../errors-logs-messages-crashes-autoplant-modeler
Still a Problem?
If the problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include the list of all relevant details to get in depth analysis for solution or workaround.
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this wiki entry to this Comments or Corrections?" section. THANK YOU!
