| Version(s): | 08.11.09.XXX(SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Properties |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In order to pull the values from the spec for a component to have it populated in the corresponding property, that property needs to be mapped to spec field. This article will explain how to map the spec field with properties. We will take two examples;
CASE 1: We will take PIPE_OD_M field from PIPE table and map it with Outside Diameter property on PIPE class;
CASE 2: We will take HANDLE_OFFSET field from TOPWORKS table and map it with HANDLE_OFFSET property on GEARBOX_OPERATOR class
communities.bentley.com/.../properties-openplant-modeler
