| Version(s): |
08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Settings |
| Subarea: | - |
| Original Author: | Deepak Singh,Bentley Product Advantage Group |
To define spool ID start point for piping arrangement in OpenPlant Modeler.
In OpenPlant Modeler, spool Id constitutes of the SPOOL_PREFIX, defined on the pipeline, and a number at the end that uniquely identifies that spool in that particular pipeline. We can define start point for generation of spool id from desired piping component in proper sequence. This wiki article explain how to define spool id start point for a piping arrangement.
In OpenPlant Modeler, generating spool ids doesn't result proper sequence of spool ids.User requirement is to define a start point for generation of spool id in sequence. As shown in below image, user want to define or start spool id from highlighted pipe in a proper sequence
communities.bentley.com/.../22438.how-to-change-numbering-sequences-for-spools-welds-cutid
