| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Properties | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Technical Support Group | ||
This article will explain how can we change the Units of Measurement of any EC Property for any class. The example of an Out of Box Metric project is taken to demonstrate but the procedure is same for every project. TEST_PRESSURE property on PIPING_NETWORK_SYSTEM has been taken as an example.
Find the Class you will be modifying and click on the properties tab.
Find the property you'll be changing, TEST_PRESSURE in this case, select it.
In the Units tab, change the Unit value from KILOPASCAL_GAUGE to MEGAPASCAL.
