| Version(s): | 08.11.09.XXX (SS5) & 08.11.11.XX (SS6) |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To create a new property & make its field editable for any component or fittings at the time of placement in OpenPlant Modeler.
Problem Description
User requirement was to add a new property and inside the Modify Component dialog box, user should be able to fill in the desired information.Below steps illustrates on adding new Property & defining custom attribute to a new property in schema to make it available for editing. Few new properties like XYZ, ABC needed to add inside specific Categories like Operating Conditions/Design Conditions etc. Below steps will aid user to achieve the desired configuration, explaining each methods.
Steps to Resolve
Adding a New Property Under PIPING_COMPONENT Class
- In Class editor, Open "OpenPlant_CustomAttributes.08.11.ecschema.xml" schema to get the desired custom attribute on certain class, as it contains the list of Custom Attributes.
This schema can be found by navigating below path - %Project Root%\WorkSpace\OPModeler\schemas
- Again open "OpenPlant_3D.01.07.ecschema.xml" and supplement it with "OpenPlant_3D_Supplemental_Modelingviews.01.04.ecschema.xml" schema.
Above schema can be found by navigating below project path:
%ProjectRoot%\DataSet\Schemas. For More information on supplementing schemas click here>>>>
- Locate the PIPING_COMPONENT class. User may also use binocular option & write directly the class name if known and do a search. See image below.
Note -To Notice, these properties are created under Piping component, hence it should get displayed when piping component classes are used & only get displayed under element information. To display any property under pipeline level, property should get created under Pipeline (PIPING_NETWORK_SYSTEM) class.
- Click on Properties Tab, which contains list of default properties available on certain class.
- To Create a new property, click on Add.. option like displayed in image below.
- By default a Property with name property gets created to be edited by user as per project instance data name.
- Enter Name, DisplayLabel, and TypeName (Datatype format), as defined for instance data. Say XYZ to be displayed under category Operating Conditions tab.
- Add Custom attribute Category on new property XYZ. User can copy this from any existing property in the list. say WALL_THICKNESS here. See image below.
- Copy it from WALL_THICKNESS property.
- Pull Category custom attribute to down for selection and click on copy.
Note -Define Location to OpenPlant_3D_supplemental_ModelingViews.01.07
- Paste it on new XYZ property. See image below.
- Custom attribute gets added to new property XYZ. See image below.
- Save & Close schema.
Add new property ABC inside EQUIPMENT class under Design Conditions tab.
- User need to add the property under Primary schema level. Since other existing properties has been defined under it.
- Open OpenPlant.01.07.ecschema.xml. Supplement it with OpenPlant_Supplemental_Units_Metric.01.07.ecschema.
- Navigate to EQUIPMENT class, check existing properties present under design Conditions tab, say LOWER_LIMIT_DESIGN_PRESSURE
- One easier way is to copy the existing property and paste it & modify it for desired use.
- Rename copied property as desired, say ABC here. See image below.
- Save Schema.
- Launch OpenPlant Modeler.
- Place Equipment and enter data. See results below.
Adding Units to Properties
- For Some design parameter unit or suffix may require to add /remove or modify which can be further added using Add Units option. See image below.
- Select the desired units if needed to change.
Note -Click these links to refer Remove Units>>>> & Modify Units >>>> from existing properties.
To Make New Property Field editable.
- To create new property field Editable, add Custom Attribute "Property Display Status" and assign the location like shown in image below.
Note- Ignore adding the custom attribute again, if it is already present on some properties.
- Set the value for both fields as per requirement.
Note – User can use options provided under this field like to Hide, Read & editable as per requirement in OpenPlant Modeler.
- Launch OpenPlant Modeler & verify results.
For Pipe:
communities.bentley.com/.../20185.how-to-make-design-fields-editable-for-cube-operator
See Video
communities.bentley.com/.../273203
