Scaling the Drawing Title Label in Structural DocumentationCenter TN
Scaling Drawing Title
You can right-click on the Drawing Title cell and select Scale. The Scale tool settings dialog box will open and you can enter a new scale.
Below is a copy of a test Drawing Title and then scaled it by 2.0.
