| Version(s): |
08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Pipeline Manager |
| Subarea: | Stress Interface |
| Original Author: | Deepak Singh,Bentley Product Advantage Group |
In OpenPlant Modeler, how to fix error for unable to load schema for StessApp in OpenPlant Modeler
From Pipeline Manager, upon using Export Data for Stress Analysis feature, throws error as “Unable to load Schema for StressApp”. Refer below image, such issue can be seen due to incorrect installation of OpenPlant Modeler or due to schema file missing from specific directory. This wiki will explain how to fix this error.
In case if above highlighted schema file is not present, copy stressapp.01.01. ecschema file from another machine where OpenPlant Modeler is installed & paste it to above highlighted location.
Note: Before proceeding above step, ensure to have backup of your workspace.
communities.bentley.com/.../errors-logs-messages-crashes---openplant-modeler
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
