To Add Prefix "M" For Bolts In Bill Of Material- v8i
Product(s):OpenPlant Modeler
Version(s):
08.11.09.XXX (SS5) | 08.11.11.XX (SS6)
Environment: Windows 7/8.1/10 (64-bit)
Area: OpenPlant Isometrics Manager
Subarea: Iso-Generation
Original Author:Deepak Singh,Bentley Product Advantage Group
To add prefix "M" for bolt size in bill of material.
Problem Description
In OpenPlant Isometrics Manager, user wants to add prefix "M" for size of bolts.This can be achieved by creating a new report for bolt in report definition file of respective style folder.
Note: To see the correct result ensure that during modeling bolt diameter sizes are in metric unit.
Steps to Reproduce
  1. Open report.def file of your particular style folder.
  2. Scroll down to FLD report. Exclude bolt from this report, see below image.
    EXCLUDE = IE_TYPE=CT_WELD|CT_BOLT
  3. Create a new BOLT report, to add prefix M, concatenate M with SIZE refer below image.
    REPORT = BOLT
    EXCLUDE = IE_TYPE=CT_WELD|CT_GASKET
    INCLUDE = IE_TYPE=CT_BOLT
    COLUMN = 3: R : PARTID
    COLUMN = 20: L : "M"+SIZE
    COLUMN = 7: R : QUANTITY
    COLUMN = 60: W : IE_DESCRIPT
    COLUMN = 2:
    GROUP = PARTID
    SORT = PARTID:N
    SEP = @
    SORTHEADERS = 1
  4. Modify combi report, refer below image.
  5. Save settings and verify the result as shown below.
communities.bentley.com/.../to-display-bolt-length-as-metric-in-bom-description
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Comments or Correction?
