| Product(s): | AutoPLANT Plant Design |
| Version(s): | V8i, XM, 2004 |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Joey Bertone, Bentley Product Advantage Group |
The AutoPLANT Object Enabler is an AutoCAD plug-in that allows users who do not have AutoPLANT installed to view AutoPLANT objects in AutoCAD. Without Object Enablers installed users will see AutoPLANT objects as wireframe cubes and rectangles.
The AutoPLANT V8i object enablers can be downloaded by selecting required version in this wiki:
communities.bentley.com/.../autoplant-modeler-v8i-object-enabler-for-autocad
http://appsnet.bentley.com/myselectcd/default.aspx
