| Version(s): | 08.11.09.404 (SS5) & Above |
| Environment: | Windows 7 (64 bit) |
| Area: | Component |
| Subarea: | Graphics |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Add Custom Valves in Schema for OpenPlant Modeler.
As per project requirement Custom valves needed to add in OpenPlant Modeler. Below steps illustrates how to add Custom Valves in Schema. User need to add desired class in schema, under the Valve class which exhibits same property. Further by placing it through ‘Create New Custom Component’ option it will inherit the same property like other valve class and deliver the same results like default existing one.
Note: - To use spec data, user needs to add CUSTOM_VALVE class in Catalog Editor and then create spec with available information. This will enable user to use ‘Use Spec Data’ option. See image below.
See Help Menu for 'Add Custom Attributes for a Class' for more details.
Check Similar helpful link on adding valve type in catalog editor:
communities.bentley.com/.../how-to-configure-welded-relief-valve
communities.bentley.com/.../how-to-create-multiport-custom-valve
