| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Graphics |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In OpenPlant Modeler, to use existing class as Custom Component.
As per project requirement custom components are required which are not available in library by default. Modeler have the flexibility to use existing class and define it for custom component. In OpenPlant Modeler use existing class for custom component can be done by adding custom attribute “Use Class as Custom Components” under OpenPlant_3D_Supplemental_Modeling.01.04. Ecschema.xml. Below steps will illustrate one if the existing class use and to enable it to show in drop down list under custom piping component builder dialog box. Below example is take for class TEE_SHOE under Support discipline. Similar approach can be made for other discipline like Piping and various class use.
See Help Menu for 'Add Custom Attributes for a Class' for more details.
Check Similar helpful link on adding valve type in catalog editor:
communities.bentley.com/.../how-to-configure-welded-relief-valve
communities.bentley.com/.../how-to-add-custom-valves-in-schema
communities.bentley.com/.../how-to-create-custom-components-from-cell
communities.bentley.com/.../how-to-create-multiport-custom-valve
