| Version(s): |
08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Customization |
| Subarea: | Schema |
| Original Author: | Deepak Singh,Bentley Product Advantage Group |
In OpenPlant Modeler, requirement is to map custom property whose data type is double in OpenPlant Modeler
In OpenPlant Modeler, mapping a custom property whose data type is double doesn’t fetch desired values from spec database. Below wiki article explains how to achieve this in OpenPlant Modeler.
communities.bentley.com/.../how-to-map-spec-data-for-double-type-property-in-openplant-modeler
