| Version(s): | 08.11.11.87 (SS6) & Above |
| Environment: | Windows 7/8.1/10 (64 bit) & Others |
| Area: | Component |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To fix “Structural Synchronizer Engine Not Found” message in OpenPlant Modeler.
With latest version from 08.11.11.87, there is a new tab called “Structural”. While selecting “Open repository” option, it sometimes gives below message as “Structural Synchronizer Engine Not Found” along with below details. See image below.
See Message below:
The ISM_ENGINE_PATH configuration variable “ is set to a non-Existent application. Please update the configuration variable in config\appl\StructuralModelingComponents.cfg. The ISM Import and Export features require this Setting.
This is happening because of missing Structural Synchronizer Engine not installed on system. To overcome the situation, user need to install Structural Synchronizer to use this feature from software Fulfillment Centre. See below steps to resolve it.
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
