Product(s): | Bentley Raceway and Cable Management | ||
Version(s): | 08.11.07.77 | ||
Environment: | Windows 7 64 bit | ||
Area: | Installation_Configuration | ||
Subarea: | N/A |
DDE Server Window: BRCM.exe - Bad Image
C:\Windows\system32\butil.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact you system administrator or the software vendor for support.
The butil.dll file does not seem to be compatible with newer operating systems. Unsure of what application installed this file or why it is called when BRCM is run.
Rename the butil.dll file in the following folders:
C:\Windows\SysWOW64\
butil.dll is not a valid windows image
Original Author: | Bentley Technical Support Group |
