Error - SQL state S1010 Function sequence error
 Product(s):Bentley Raceway and Cable Management
 Version(s):08.11.07.xx
 Environment:N/A
 Area:Installation_Configuration
 Subarea:N/A
Error or Warning Message
An error message that includes the following text occurs frequently when updating the database:
SQL state: S1010
SQL Error: [Microsoft][ODBC Driver Manager] Function sequence error
How to Avoid
Include "MARS_Connection=yes" in the value for BRCM_DB_CONNECTSTRING.
  1. Open the .PCF file for a problem project in Notepad
  2. Append ";MARS_Connection=yes" to the BRCM_DB_CONNECTSTRING line.  For example:
    BRCM_DB_CONNECTSTRING=DSN=BRCMUSER;UID=BRCMUser;PWD=brcm;MARS_Connection=yes
 Original Author:Matt_P
