Applies To | |
Product(s): | OpenPlant Isometrics Manager |
Version(s): | 08.11.11.224 (SS6) |
Environment: | Windows 7/8.1/10 (64 bit) |
Area: | Settings/Attributes |
Subarea: | Dimension |
Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To convert Pipe diameter & Dimension in different unit in Isometric drawings.
With the latest release of OpenPlant Isometrics Manager, Dimension of a pipeline and Pipe diameter inside the BOM can be converted. A new two variables have been added to allow user to convert the unit from Metric to Imperial or vice versa. Ensure project units are different to enable it to produce desired result.See below steps to use this option. Below example has been taken to convert the Metric unit to Imperial. See default dimension & pipeline diameter extracted in Metric unit.
Dimension
Diameter
Note - User may also use Dual dimensions to display both units in one isometrics, which could be used anywhere. Click here >>>> to refer link describing dual dimension on Isometrics.
communities.bentley.com/.../modifying-dimensions
