Use of Flag on User labels in OpenPlant Isometrics Manager-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX (SS5) | 08.11.11.XXX (SS6)
Environment: Windows 7/8.1/10 (64bit)
Area: Settings/Attributes
Subarea:
Original Author:Kestutis Mitkus, Bentley Product Advantage Group
This is a possible list of Flag Options which can be used for User Labels modifications. Some examples are already posted in our Bentley Communities with detail instructions and in this wiki you will find a complete list of possible Flag options with links to related articles.
Possible list of the Flag options
  1. S - display this user label only once for a spool.
    Click here>>> to refer related article for further help
  2. P - display this user label only once for a pipe cut (sequence of pipes/bends).
  3. I - place the label text in the component cell instead of a separate label.
    An option is offered to place the content of a user label inside a component cell. An example of this is show below where an instrument tag is to be displayed within a gauge symbol.
  4. E - apply the user labels to existing components as well.
    Normal the INCLUDE/EXCLUDE rules only operate on NEW type component, those that are listed on the BOM and existing component are not included in the basic selection set used for user labels. You can however force them to be included by adding an E to the flags field.
  5. - - Any hyphen in the label text will be interpreted as a line break.
    This indicates the label routines to interpret hyphens in the label text portion as a text separator. The text part can then either be distributed among different field in the label or displayed in a multi line fashion. This is specifically for tags like HV-100 that need to spread over two lines, one with HV, the other with 100.
communities.bentley.com/.../to-modify-the-spool-id-labeling-in-openplant-isometrics-manager
communities.bentley.com/.../to-customize-spool-labels-based-on-cutid-and-other-attributes
communities.bentley.com/.../how-to-use-custom-cell-as-user-labels-for-instrument-symbol
Comments or Corrections?
