Applies To | |||
Product(s): | AECOsim Building Designer | ||
Version(s): | 08.11.09.747 | ||
Environment: | N\A | ||
Area: | Structural Design | ||
Subarea: | Concrete Members | ||
Original Author: | Robert DiMauro, Bentley Technical Support Group | ||
Can a Slab have a Sloping Elevation Point?
Slabs and Slab Forms are only planar elements and cannot be sloped at any points. If you need to create a slope for a drain in a slab, it might be better to use a Free Form where any of its points can be on a different elevation.
