| Version(s): | 08.11.09.829 | ||
| Area: | Utilities | ||
| Subarea: | Standards Checker | ||
| Original Author: | Marc Thomas |
The Standards Checker is one of many MicroStation platform features available in AECOsim Building Designer. Some detailed notes are located in the MicroStation wiki, here is a brief digest with pointers to the relevant help sections:
The help for this feature is in the ABD help section: MicroStation > Setting Up Projects > Ensuring Standards Compliance.
Next time you run the Standards Checker in a project file you should see the names of the setting you created listed in the Setting Name pop-down.
Ensure that standardschecker.xsl is present in the location defined by MS_STANDARDSCHECKER_STYLESHEET to include the html styling required for correct display of any reports.
Please see the help section 'Running Standards Checks as a Batch Process' for guidance on running the checks on multiple files.
Getting Started With The Standards Checker
Building Product TechNotes And FAQs
