| Product(s): | AutoPLANT Modeler V8i |
| Version(s): | SS5 | SS6 | SS7 | SS8 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | AutoPLANT Modeler V8i Enhancements |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
AutoPLANT Modeler V8i (SELECTseries 8) Refresh 3 Enhancements
General AutoPLANT Enhancements
- Support of AutoCAD 2017 and/or AutoCAD 2016 Support
- SQL Server 2016 Support
- Oracle 12c Support
- CONNECT Advisor Integration
- Citrix Support
- Silent Installation suppressing all dialogs
- Availability of AutoPLANT Object Enabler for MicroStation CONNECT
AutoPLANT Modeler Enhancements
- Ability to reset specifications in Advanced Routing
- Ability to specify using same specification and joint for all Pipes during Split Pipe process
- Updated Support Browser functionality to .NET for better performance
- Ability to use SPOOL in the AutoPLANT selections
- Performance improvement in Update Work Area feature
- Ability to generate Project Isometrics
- Ability to set the Connections Criteria and Naming Rules to generate isometrics
- Automatically register Isometrics to AutoPLANT project when posted to ProjectWise
AutoPLANT Modeler V8i (SELECTseries 8) Enhancements
- Windows 10 Support
- AutoCAD 2016 Support
- Advanced Routing Improvements
- Support for OpenPlant Orthographics Manager
- Publishing data to CONNECT Project through APIMC
- Automatic splitting of Isometrics
AutoPLANT Modeler V8i (SELECTseries 7) Enhancements
- Windows 8 Support
- AutoCAD 2015 Support
- Microsoft Office 2013 Support
- Microsoft SQL Server 2012 and 2014 Support
- Oracle Database 12c Support
- Support for Bentley CONNECT Services
- Advanced Routing
- Updates to Change Size / Change Specs
AutoPLANT Modeler V8i (SELECTseries 6) Enhancements
- AutoCAD 2014 Support
- Microsoft SQL Server 2012 Support
- Creating/Editing ProStructures drawings through Bentley Vision
- Creating/Editing Bentley OpenPlant PowerPID documents through Bentley Vision
- Opening/Editing Bentley OpenPlant PowerPID documents through Bentley Data Manager
- AutoPLANT supported to use OpenPlant Isometrics Manager's Extended Drawing Attributes feature
- AutoPLANT supported to use OpenPlant Isometrics Manager's Gridline feature
- Detail Sketches in Isometrics generated from OpenPlant Isometrics Manager
- AutoPLANT Modeler's Instruments module components supported in Isometric generation through OpenPlant Isometrics Manager
Bentley Instrumentation & Wiring Enhancements
- Applying Revision Markings to an Instrumentation document in a ProjectWise enabled AutoPLANT project
- Applying 'Attribute' values from ProjectWise Explorer updates the values in the Title Block of the loop drawing
- Filtering components having associated Tstrips
AutoPLANT V8i (SELECTseries 5) Enhancements
- Installer Changes - Prerequisites and Common Tools for AutoPLANT Applications
- Auto Installation
- Patch Update Support
- Support for ProjectWise V8i (SELECTseries 4) Refresh Client
- OpenPlant Isometrics Manager V8i (SELECTseries 5) Integration with AutoPLANT Modeler V8i (SELECTseries 5)
- Improvements to Briefcase mode drawing generation process via ProjectWise Explorer
- Copying drawings from one ProjectWise enabled AutoPLANT Project to another within the same datasource
- New Icons for ProjectWise enabled AutoPLANT projects in ProjectWise Explorer and Project Administrator
- Launching Data Manager from ProjectWise Explorer
- Permission to update AT.ini for Standard Users
- Improvement to Equipment's Consistency Checker
- Changing 'Application' of a drawing from ProjectWise Explorer
- Add possibility to disable AutoPLANT Modeler's application launch when loading a drawing in ProjectWise enabled project
- ProjectWise dialog to Insert Drawing References or Blocks displayed for Briefcase mode drawings
- Changing document location in ProjectWise Explorer
- Improvements to Publishing Data Manager reports to ProjectWise
- Registering Non-AutoPLANT documents
- Implementation of 'Document Registry Cleanup' tool in ProjectWise Explorer
- Remotely Update Project Reports
- Installer Changes - Prerequisites for Bentley AutoPLANT Applications
- Auto Installation
- Bentley ProjectWise V8i (SELECTseries 4) Refresh Client Support
- Distinguishing ProjectWise enabled AutoPLANT projects from others in ProjectWise Explorer and Project Administrator
- Loading Data Manager from ProjectWise Explorer
- Datasheet creation using ProjectWise Document Code
communities.bentley.com/.../bentley-autoplant
communities.bentley.com/.../autoplant-modeler-faq
