| Product(s): | AutoPLANT Plant Design V8i and AutoPLANT Modeler V8 |
| Version(s): | SS1 | SS2 | SS3 | SS4 | SS5 | SS6 | SS7 | SS8 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | N/A |
| Original Author: | Keith Couvillion, Bentley Product Advantage Group |
AutoPLANT Modeler primarily comprises of Piping, Equipment and Raceways. Piping itself consists of multiple modules like Cable Tray, Conduit, HVAC, Instrument, Ductile Iron, Plastic, Refrigeration, Lined Pipe, Tubing, High Purity, Victaulic and Jacketed Piping, each being used while modeling a for a specific industry.
Apart from the above modeling applications, there are applications to generate or modify the specs and catalogs that are being used about above applications to operate.
communities.bentley.com/.../bentley-autoplant
communities.bentley.com/.../autoplant-modeler-faq
