| Product(s): | AutoPLANT Modeler V8i |
| Version(s): | SS5 | SS6 | SS7 | SS8 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | N/A |
| Original Author: | Bentley Product Advancement Group |
What are the latest versions of AutoPLANT Modeler?
The following AutoPLANT Modeler versions are available from Bentley Systems’ Fulfilment Center .
AutoPLANT Modeler V8i (SELECTseries 8) Refresh 3 for AutoCAD 2016/2017 x64
AutoPLANT Modeler V8i 08.11.14.124
Prerequisites and Common Tools for Bentley AutoPLANT V8i 08.11.14.124
See the ReadMe for more information:
https://communities.bentley.com/products/plant/m/plant_design_and_engineering_files/273270
AutoPLANT Modeler V8i (SELECTseries 8) for AutoCAD 2016 x64
AutoPLANT Modeler V8i 08.11.13.211
Prerequisites and Common Tools for Bentley AutoPLANT V8i 08.11.13.211
Prerequisites and Common Tools for AutoPLANT Applications v8i x64 Update 2 08.11.13.245
https://communities.bentley.com/products/plant/m/plant_design_and_engineering_files/272397
AutoPLANT Modeler V8i (SELECTseries 7) for AutoCAD 2015 x64
AutoPLANT Modeler V8i 08.11.12.226
Prerequisites and Common Tools for Bentley AutoPLANT V8i 08.11.12.226
Prerequisites and Common Tools for AutoPLANT Applications v8i x64 Update 2 08.11.12.252
https://communities.bentley.com/products/plant/m/plant_design_and_engineering_files/271327
AutoPLANT Modeler V8i (SELECTseries 5) for AutoCAD 2012 x64 & x32
AutoPLANT Modeler V8i 08.11.10.182
Prerequisites and Common Tools for Bentley AutoPLANT V8i 08.11.10.182
https://communities.bentley.com/products/plant/m/plant_design_and_engineering_files/272921
