| Product(s): | AutoPLANT Modeler V8i |
| Version(s): | SS5 |
| Environment: | N/A |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | N/A |
| Original Author: | Keith Couvillion, Bentley Product Advantage Group |
Isogen is no more available in AutoPLANT, instead, OpenPlant Isometrics Manager is to be used with AutoPLANT SS5.
Users may use OpenPlant Isometrics Manager with AutoPLANT Modeler SS5 to generate Isos from within AutoPLANT Modeler in the same way as used with Isogen.
Users can also use OpenPlant Isometrics Manager to generate Isos without having to load AutoPLANT Modeler by directly connecting to database. Users will have to install Plant Framework (or AutoPLANT Modeler) alongside OpenPlant Isometrics Manager to achieve this.
communities.bentley.com/.../bentley-autoplant
communities.bentley.com/.../autoplant-modeler-faq
