| Version(s): | 08.11.09.829 | ||
| Area: | Platform Tools | ||
| Subarea: | N\A |
It seems that some of the references are not displaying in the correct order, how to change their order to display differently in the model?
The update the references use the sequence tool In the References dialog box, select Settings > Update Sequence. The Update Sequence dialog opens. The list box shows the current update sequence.
| Original Author: | XXXXAuthorXXXX |
