| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | All versions |
| Environment: | - |
| Area: | - |
| Subarea: | - |
| Original Author: | Bentley Global technical Support Group |
Yes, OpenPlant Isometrics Manager has an option to create a PCF with evey isometric that is generated. The PCF can then managed by ProjectWise similar to how the isometric drawing is handled.
Yes, OpenPlant Isometrics Manager generates PCF file to get it readable in AutoPipe.
No, we do not plan on providing automatic syncronization of isometric drawing data due to model changes.
We do however plan on providing consitency checks between the isometric and the modeled piping components based on design states in future versions.
Yes, with latest release of OpenPlant Modeler 08.11.11.238 SS6 Isometric creation is done with in session.This allows non-piping (lower cost) project participants to produce isometrics.
Also this provides an opportunity to create piping isometrics from other plant design tool set via i-models.
User can check in Help file Menu. Check link below for a quick view where helpful links are also attached to describe each cases.
Refer link for What's New - What's New - SELECTseries 6
Refer link for what's new- What's New - SELECTseries 5
Check Videos Content - LEARN Server
