MSXML2 publicKeyToken error in tfdgschedules.dll
 Version(s):08.11.09.863
 Environment:N\A
 Area:General
 Subarea:Errors
Error or Warning Message
We are getting the following error in the Windows event log.  How can we fix this?
<Data>Microsoft.MSXML2,language="&#x2a;",processorArchitecture="X86",publicKeyToken="6bd6b9abf345378f",type="win32",version="4.20.9818.0"</Data>
  <Data>C:\Program Files (x86)\Bentley\AECOsimBuildingDesignerV8i\AECOsimBuildingDesigner\mdlapps\tfdgschedules.dll</Data>   </EventData>
  </Event>
How to Avoid
It's possible that a schedule layout XML file (or files) under the C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i\WorkSpace\BuildingDatasets\Dataset_Name\datagrouplayouts\ folder is either missing or corrupt.  The best option is to first rename that existing folder in your active workspace, copy the \datagrouplayouts folder from the applicable delivered AECOsim Building Designer dataset, and paste that to your workspace's folder (where the existing folder was already renamed).   After restarting AECOsim Building Designer the error should no longer occur.  If so, copy any modified and/or additional XML files from the renamed folder to the new version in order to retain your customized DataGroup Schedule layouts.
 Original Author:Steve Cocchi
