| Version(s): | 08.11.09.863 | ||
| Area: | Platform Tools | ||
| Subarea: | N\A |
When I try to snap on elements in the model the snap option always defaults back to "Keypoint" but I preffer to use Multi-Snap. How to set snap so that Multi-snap is set as default?
From: Design File Settings > Snaps > Modify Snap Settings > Mode > from the drop down menu select Multi-Snap.
| Original Author: | XXXXAuthorXXXX |
