| Version(s): | 08.11.09.593 | ||
| Area: | Operation | ||
| Subarea: | Installation | ||
| Original Author: | Robert DiMauro, Bentley Technical Support Group | ||
How can AECOsim Building Designer be silently installed without any prompts?
Please note that the steps below also apply to AECOsim Building Designer SS6 and see Enabling Silent Removal of Datasets - AECOsim Building Designer for additional functionality in SS6.
Be able to start the installation and not having to monitor it to answer any prompts.
Select the Create Deployment image option.
Click Create, Next
Select “Advanced Settings” button and “Silent mode installation”.
Click Next
Click Typical for normal installation.
Click Install.
Click Finish.
The results should yield a folder with the following deployment files in it:
AECOsim Building Designer Silent Install Commands
| Original Author: | Robert DiMauro |
